RobertHD
Aug 28, 2020Guide
Orbi Netgear App drops Satellite devices from display
I have the router in the basement, and satellites on the first and second floor. Firmware version for the app is V3.2.16.6_1.4.4. I have 28 devices connected and distributed between the 3 points. Bac...
Aug 28, 2020Guru - Experienced User
I haven't seen this with mine. I see Orbi app has been updated as well in the past few days for Apple and Yesterday for Google. You might remove the app and re-install then walk thru a new setup proceedure in the app.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Has a factory reset been performed on the orbi ax system since last FW update?
Something to post about over in the Orbi app forum as well:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
RobertHD
Sep 06, 2020Guide
Thanks for the reply. My 2nd floor sattelite went offline again this morning and reminded me to check my post.
The house is only 2,100 Sq Ft and built 20 years ago. No special construction. Just normal wood frame and sheetrock. Distance between Router and the 2 sattelites is well within 30 feet.
The funny thing is, my desktop was still on the internet even though the app did not show the the desktop being connected. As soon as I unplugged the sattelite, the internet was lost. I plugged it back in and hit the sync button. I got the internet back on my desktop but still not seeing the 2nd floor sattelite or my desktop in the app. I rebooted the router (from the app) and all 30 devices then appeared along with the 2nd floor sattelite.
I'm a little hesitant to do a factory reset (although I did create a backup). I'm okay with uninstalling and reinstalling the app. I'll give that a shot this week.
Thank you!
Bob D
- FURRYe38Sep 07, 2020Guru - Experienced User
This maybe an issue withe just the app and not the actual RBS,
I would make a new post over in the Orbi app forum regarding this:
