RobertHD
Aug 28, 2020Guide
Orbi Netgear App drops Satellite devices from display
I have the router in the basement, and satellites on the first and second floor. Firmware version for the app is V3.2.16.6_1.4.4. I have 28 devices connected and distributed between the 3 points. Bac...
P_J_G
Nov 21, 2020Aspirant
Same issue here - Router plus 2 Sat's - network is fine - devices can connect etc. iPhone app doesn't show all connected devices although they are obviously connected. Doesn't look like an app problem though, because directly connecting to the router shows the same devices. Netgear - you obviously know about this problem - it's not ok to just let it continue. Being able to see what is on the network is fundamental - If this was a $59 router I may be more understanding, but a $599 system - not ok.
RBR750 with V3.2.16.6_1.4.4 firmware.
- FURRYe38Nov 21, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
P_J_G wrote:Same issue here - Router plus 2 Sat's - network is fine - devices can connect etc. iPhone app doesn't show all connected devices although they are obviously connected. Doesn't look like an app problem though, because directly connecting to the router shows the same devices. Netgear - you obviously know about this problem - it's not ok to just let it continue. Being able to see what is on the network is fundamental - If this was a $59 router I may be more understanding, but a $599 system - not ok.
