mws1984
Sep 18, 2024Aspirant
Orbi network constantly dropping service
Have an Orbi Mesh network. One router and a satellite. Model RBR750 on router. Despite my amazon order showing it as RBK752. I have my Verizon gateway in my office and that is hard wired to th...
Sep 18, 2024Guru - Experienced User
Does the front LED on the RBR turn PINK when this happens?
I have my Verizon gateway in my office and that is hard wired to the Orbi router. PC is hard wired to the router also. Then other devices on the network are using wifi off the orbi satellite that is positioned midway thru the house. Too much cable to do hard wiring on everything so chose this option.
So already twice since last night I've had Orbi drop service. I only changed the gateway yesterday evening around 7pm. I have no idea why the Orbi is disconnecting from a hard wired internet connection source. Is there some setting that is causing it to drop. Was literally in the other room and suddenly I check and lost connection. Check the router and it is lit up pink indicating no connection. My Verizon gateway was working just fine it was functioning.
I really cannot determine what is going on here and why I keep losing service. It seems there is something causing the Orbi to disconnect from the Verizon. Is there some setting somewhere I need to change or what might be going on? I've posted something similar on Verizon and Microsoft pages in case it might be my PC or Verizon connection. This happening is far from ideal because if I am out of town then I cannot just reset the connection since I have cameras that need accessibility.
- mws1984Sep 18, 2024Aspirant
Yes the LED turns pink. So my understanding is that it means it has no connection. Then I end up unplugging the Verizon gateway to reset it.
- FURRYe38Sep 18, 2024Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- mws1984Sep 18, 2024Aspirant
I'll give that option 2 a try. Just doesn't seem ideal that cannot access things on the Orbi app, but guess just would need to switch it back how it was if needed to do anything. Only time will tell if this fixes my issue. Still unsure what the deal is when my computer wakes up it will have a pop up "internet connection restored" I'm not exactly sure what would make it disconnect or why I get that message. It shouldn't be disconnecting at all. Definitely saving this post and the site with instructions so I know what to do if I need to change things back.
