mws1984
Sep 18, 2024Aspirant
Orbi network constantly dropping service
Have an Orbi Mesh network. One router and a satellite. Model RBR750 on router. Despite my amazon order showing it as RBK752. I have my Verizon gateway in my office and that is hard wired to th...
mws1984
Yes the LED turns pink. So my understanding is that it means it has no connection. Then I end up unplugging the Verizon gateway to reset it.
Sep 18, 2024Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- mws1984Sep 18, 2024Aspirant
I'll give that option 2 a try. Just doesn't seem ideal that cannot access things on the Orbi app, but guess just would need to switch it back how it was if needed to do anything. Only time will tell if this fixes my issue. Still unsure what the deal is when my computer wakes up it will have a pop up "internet connection restored" I'm not exactly sure what would make it disconnect or why I get that message. It shouldn't be disconnecting at all. Definitely saving this post and the site with instructions so I know what to do if I need to change things back.
- mws1984Sep 18, 2024AspirantThat definitely messed things up. Now my cameras that were linked to my Orbi are no longer connected. I’m guessing since I can’t access anything linked to my Orbi on the app due to the way it’s setup as suggested. Any ideas?
Something is definitely not right. I was out and went to check on cameras at home and they were offline. I check the Verizon gateway and it was also offline. I could not reset it from my Verizon app. Told me to check what colors it was lit. So had to wait til I was home. I get home the gateway still appeared working but the Orbi was lit pink again like it got disconnected. This was all after putting it into the suggested "AP mode" under the advanced settings. I reset the gateway and everything connected back up again. I have no idea what is going on. Getting to be such a hassle to have steady consistent internet.
- FURRYe38Sep 19, 2024Guru - Experienced User
Seems like something is happening with the Verizon unit. You'll need to contact the ISP and have them take a look at the unit and signal leading up to the unit and make sure things a good up to the ISP unit.
