PJDarwin
Jul 06, 2023Aspirant
Orbi not connecting to Starlink
I received my Starlink in November 2022, despite reading the issues others were having with connecting to an Orbi system I had none. The Orbi established a WAN connection to the Starlink which I the...
Jul 07, 2023Guru - Experienced User
Is the starlink in passthrough mode? or the netgear in access point mode?
Or you're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
