HomeUserguy
Dec 01, 2020Aspirant
Orbi not passing traffic
I have an orbi 3 node RBR850 setup but also have a managed switch that links into the the orbi devices. I can connecto the the switch via the web interface however I have a tool that uses SNMP and c...
HomeUserguy
kinda confused by some of the responses..... I dont have any network flow problems... All my devices are just find to incude my managed switch. I have a utliity that is trying to connect to my managed switch via SNMP and it never seems to connect. I was just looking to see if orbi is block the SNMP connect from a wifi device to the switch management port. I have no problem connecting to the port on 443/80 etc
schumaku
Dec 02, 2020Guru - Experienced User
As confusing as the original subject and post was, sorry 8-)
Have no Orbi AX system at hand for a test. of course it should not randomly block neither SNMP nor any other traffic.
Worth checking the switch SNMP config for the allowed SNMP management station address and subnet - well possible your computer does get a different IP address on Ethernet vs. WLAN.
