HomeUserguy
Dec 01, 2020Aspirant
Orbi not passing traffic
I have an orbi 3 node RBR850 setup but also have a managed switch that links into the the orbi devices. I can connecto the the switch via the web interface however I have a tool that uses SNMP and c...
Dec 26, 2020Guru - Experienced User
I don't believe Orbi systems offer any kind of SNMP features.
HomeUserguy wrote:I have an orbi 3 node RBR850 setup but also have a managed switch that links into the the orbi devices. I can connecto the the switch via the web interface however I have a tool that uses SNMP and connect connect to the switch when on wifi however if I plug my computer into the switch that scan works.
I dont see anywhere the wifi is block the snmp scan from the device....
I am missing somthing? I am not trying to use SNMP for the Orbi devices just connect via SNMP to a TP Link switch.
schumaku
Dec 27, 2020Guru - Experienced User
FURRYe38 wrote:I don't believe Orbi systems offer any kind of SNMP features.
HomeUserguy wrote:I am not trying to use SNMP for the Orbi devices just connect via SNMP to a TP Link switch.
I wonder if HomeUserguy was able to resolve the issue and able to gain SNMP access through the Orbi system or if there is really an unwanted filter on port 161/UDP for SNMP polling the TP Link switch.
- FURRYe38Dec 27, 2020Guru - Experienced User
Would be interested to know...
