Trx1975
Nov 17, 2024Aspirant
Orbi often magenta
Hi, not happy with my rbr760 and 2 sattelites. I have no method to link them to eachother. So current setop is modem - > switch - > wired rbr and 2x sattelites in 3 different rooms. The sattelit...
- Nov 23, 2024
Trx1975 wrote:
yes, that would be the best, but my modem and orbis are in different locations. So no Orbi near the modem/Switch A
This is a common situation which can be solved in three ways:
- Relocate the Orbi units so that the router is adjacent to the ISP modem. Perhaps relocating the two satellites will result in reasonable coverage. This will allow the Orbi router WAN port to connect to the modem and the two satellites to connect to router LAN ports (perhaps through the switch).
- Run a second Ethernet cable from the modem/switch location to the Orbi location.
Connect the Orbi WAN port to the modem with one cable (bypassing the switch).
Connect an Orbi LAN port to Switch A using the other cable.
Switch A is not connected to the ISP modem. - Place managed switches at the Orbi location and the modem location (two switches). This will allow the single Ethernet cable to function as a VLAN "trunk" and carry both the traffic between modem and Orbi WAN port and the traffic between the Satellites and Orbi LAN port over a single cable. For example, the Netgear GS105E now sells on Amazon for $40. Paying $80 for two switches might be significantly less costly than installing another cable.
- At the router location, connect the existing Ethernet cable between modem location and Orbi router location to Port 1 and define Port 1 as a VLAN trunk.
- Connect the Orbi router WAN port to Port 2 on the managed switch and define this Port as VLAN 1
- Connect an Orbi LAN port to Port 3 on the managed switch and define this as VLAN 2
- At the modem location, connect the existing Ethernet able to Port 1 and define Port 1 as a VLAN trunk.
- Connect the modem to Port 2 on the switch and define Port 1 as VLAN 1
- Connect Satellite 1 to port 3 of the managed switch and define it as VLAN 2
- Connect Satellite 2 to port 4 of the managed switch and define it as VLAN 2
A longer description of this process can be found here: https://www.dropbox.com/scl/fi/7to2s3f4rxkfqjnccvk8c/VLAN-Solution.pdf?rlkey=ywv6oxinpgpx6pqjb7ao45zd8&dl=0
Trx1975
Nov 23, 2024Aspirant
Thank you for the quick respons. My appologies for the late reply
Fiber -> Modem WAN port
Modem LAN Port 1 -> Netgear Switch A port 1
Modem LAN Port 2-4 -> other devices
Netgear Switch A port 2 -> Orbi Router yellow port, labelled "Internet". 2 ports labeled "Ethernet" connected to PC's.
Netgear Switch A port 3 -> Orbi Sat 1. Sat has 2 ports, unlabled, all white. Connected to the right port. Other port to PC
Netgear Switch A port 4 -> Orbi Sat 2. Sat has 2 ports, unlabled, all white. Connected to the right port. Other port to Netgear Switch B, with multiple devices
Netgear Switch A port 5-8 -> other devices
Also tried
Modem LAN Port 1 -> Orbi Router yellow port
Modem LAN Port 2 -> Orbi Sat 1
Modem LAN Port 3 -> Orbi Sat 2
Modem LAN Port 4 => Netgear Switch A
Same result.
Next to the sattelites going Magenta, the PC's connected to the Orbi router often experiece a short drop in internet and Wifi from the router.
CrimpOn
Nov 23, 2024Guru - Experienced User
Either of these two configurations create a network where the Orbi satellites are not connected through the Orbi router LAN ports. A configuration that should work properly is:
ISP modem/router LAN port 1 to Orbi router WAN port.
Orbi LAN port 1 to Netgear switch A port 1
Netgear switch A port 2 to satellite 1
Netgear switch A port 3 to satellite 2
other ports to other devices
- Trx1975Nov 23, 2024Aspirant
- FURRYe38Nov 23, 2024Guru - Experienced User
Any ethernet connected RBS needs to be connected behind the main RBR unit, not in parallel.
- CrimpOnNov 23, 2024Guru - Experienced User
- Trx1975Nov 25, 2024Aspirant
Thanks! I tried bringing the Orbi router to my ISP-modem, although that is not too good for wifi-coverage.
All my switches are already the GS105E(!) (and the 8 ports version). So I will also try that solution later.
Many thanks for the quick and complete reply!
