Jeepville
Jan 11, 2020Follower
Orbi Port Forward Feature Request
I really need them to add the ability to limit who can access your portforwards by address. I could do this via DD WRT on my old router. It keeps my network much safer. So I need a source net f...
Jan 11, 2020Guru - Experienced User
Not a feature seeing in alot of home class routers. Also hopefully NG might implement Armor at somepoint in to Orbi AX or other security features. AT most, the router is secure and works well. If you needed extra security, then you may need to look into other firewall solutions or elsewhere.
Jeepville wrote:I really need them to add the ability to limit who can access your portforwards by address. I could do this via DD WRT on my old router. It keeps my network much safer.
So I need a source net filter applied to port forward. This is a major safety feature.
I have a very locked down service running on my home network and this feature blocks everyone else out.
I have a RBK52 AX6000
