Kaps_Orbi
Jan 11, 2021Aspirant
Orbi Port forwarding
I am currently having issue with orbi port forwarding where the port forward does not work until I login into the router's management web interface. Is this normal ? I have simple setup where mo...
- Jan 12, 2021
Found the source of the issue... So I am having this issue because my ISP is doing NAT444 (Carrier-Grade NAT).
This is how I found out. When I did trace route my first hope was orbi which is normal, but my second hope was not my WAN IP but some public IP of my ISP. So if anyone is having similar issue do above test if your ISP is doing some sort of NAT in their core system then port forwarding might have some issues.
Thank you everything for your contribution.
Jan 12, 2021Guru - Experienced User
Great to hear you found the problem. I presume you have to have the ISP configure something for you so your PF configuration works?
Kaps_Orbi
Jan 12, 2021Aspirant
NO.....I have not requested anything to my ISP.. I found out with port forwarding I also have to set port triggering for it to work.. I am still testing but for the past 3 hours it is working flawlessly.
- FURRYe38Jan 12, 2021Guru - Experienced User
Ah ok. Thanks for the addtional info.
Enjoy. :smileywink:
