esteb621
Jan 31, 2022Aspirant
Orbi problème avec la freebox player
Bonjour, j'ai installé un système Orbi RBK352 et je possède une freebox revolution. Le wifi du routeur est excellent je n'ai rien a redire, je l'ai mis en mode point d'acces car c'etait recommandé p...
- Jan 31, 2022
FURRYe38 wrote:en anglais s'il vous plaît
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What is the distance between the RBR/RBS and your other devices?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Sorry to bother you but I need an answer with other french guys so they can understand my problem, I'll open a new one on the good subject
Jan 31, 2022Guru - Experienced User
- esteb621Jan 31, 2022Aspirant
Sorry to bother you but I need an answer with other french guys so they can understand my problem, I'll open a new one on the good subject- FURRYe38Jan 31, 2022Guru - Experienced User
