esteb621's avatar
esteb621
Orbi problème avec la freebox player
Bonjour, j'ai installé un système Orbi RBK352 et je possède une freebox revolution. Le wifi du routeur est excellent je n'ai rien a redire, je l'ai mis en mode point d'acces car c'etait recommandé p...
  • esteb621's avatar
    esteb621
    Jan 31, 2022
    FURRYe38 wrote:
    en anglais s'il vous plaît
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What is the distance between the RBR/RBS and your other devices?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Sorry to bother you but I need an answer with other french guys so they can understand my problem, I'll open a new one on the good subject
