Utopia
Nov 27, 2022Aspirant
Orbi Quadband
Is the Orbi quadband 960 series autovolt?
Nov 27, 2022Guru - Experienced User
What do you mean by autovolt?
- UtopiaNov 27, 2022AspirantI’m planning to use it for 220 volts in the Philippines.
- plemansNov 27, 2022Guru - Experienced User
So you have one you bought in a different region and are planning on using in the philipines?
Keep in mind, some routers are region locked so you might not be able to change the region.
also, look at your power supply. some are only rated to your region. A power transformer can fix that.
Some even could use unapproved voltages because they'd be capable of covering the full range but didn't get that regions regulatory approval. but it won't be supported officially
