SimmoAu's avatar
SimmoAu
Follower
Jun 08, 2024
ORBI RB350 with 3 satellites 2 daisy chained internet issue
Hi - my Orbi set up includes 2 satellites that are daisy chained. Internet works fine around the house when in range of the router and non-daisy chained satellite. When I move to being within range of only the outer daisy chained satellite, my laptop can connect to that satellite immediately, but typically will say there is no internet connection for at least 30 minutes, before eventually finding the internet connection. Is there any way to fix this?
1 Reply
  • FURRYe38's avatar
    Can you give us a diagram of the floor lay out and indicate where the RBR and RBS are placed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
