two-dollars
Jan 04, 2023Tutor
Orbi rb750 not detecting rbs750 satellite
I've had this orbi mesh (router and two satellites) system for close to two years now. For the most part everything seemed to work ok. About two weeks ago, I noticed that one of my satellites was not ...
Jan 04, 2023Guru - Experienced User
try hardwiring it into the router and re-syncing it
- two-dollarsJan 04, 2023TutorThe router has v4.6.14.3 and so does the working satellite. The other satellite isn't visible, especially since I removed it prepared to setup fresh. It was on 4.6.9.xx.
- FURRYe38Jan 05, 2023Guru - Experienced User
Might downgrade the RBR back to 4.6.9.xx temporarily long though to see if the non working RBS will sync and connect. If it does, upgrade to v.3 then afterwards upgrade the RBR back to v.3 as well.
- two-dollarsJan 04, 2023TutorI just did that with no success assuming the process is the same as syncing when it's wireless.
