WCJ47
Nov 01, 2022Aspirant
Orbi RBK 350 connected to BT Smart Hub 2
Hi I'm having intermittent problems with an Orbi 350 linked to a BT Smart Hub 2. My internet is provided via BT Fibre 2 with a Smart Hub 2. The Smart Hub 2 is hard wired to an Orbi RBK350 with ...
Nov 01, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try Option #2 first.
Might ask the ISP if the Smart Hub can be replaced by the RBR.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
WCJ47
Nov 04, 2022Aspirant
Hi Furrye38
Opt 1 Contacted ISP they are unable to change configuration on hub.
Opt 2 Managed to disable all WiFi on hub but can't change the hub configuration used Orbi in Router mode - problem still occurs.
Opt 3 Managed to disable all WiFi and Orbi configured AP mode - problem still occurs.
I'm willing to replace hub for a RBR but don't know what a RBR is can you please explain.(network beginner).
House has 4 bedroom two stories and satellites work fine when the link is established.
Thanks for your help
WCJ47
