Kiwi-Rodney
Jan 25, 2024Aspirant
ORBI RBK 352 Ethernet ports not connecting to the Internet
I have just configured the router of this system to connect as a modem to the ISP fibre interface via the WAN port and I can now connect to the internet through the WiFi but none of the 3 Ethernet co...
- Jan 26, 2024
Problem solved after an update of router and satellite to the latest available and a power reset of downstream Ethernet switches.
Jan 26, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
