Kiwi-Rodney
Jan 25, 2024Aspirant
ORBI RBK 352 Ethernet ports not connecting to the Internet
I have just configured the router of this system to connect as a modem to the ISP fibre interface via the WAN port and I can now connect to the internet through the WiFi but none of the 3 Ethernet co...
- Jan 26, 2024
Problem solved after an update of router and satellite to the latest available and a power reset of downstream Ethernet switches.
Kiwi-Rodney
Jan 26, 2024Aspirant
Jan 27, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
