BiggieBig
May 30, 2022Aspirant
Orbi rbk 353 2.4 GHZ connection issue
Hi, I’m using a sky router and have 2 Satellites. In a remote location all my 2.4 GHZ devices stop connecting. They work during initial setup and then they all lose connection. I’ve tried the ma...
- Jun 07, 2022
Hi,
Had the same issue, could solve it by changing these settings:
Advanced - Advanced settings - Wireless settings:
2.4GHz:
- Uncheck the 20/40 Mhz coexistance
- Preambule modus : Long
Also see this thread:
Good luck!
May 31, 2022Guru - Experienced User
What is the "sky router" you're using?
the satellites work fine on 5ghz?
Did you try changing the 2.4ghz channel in case there's interference?
- BiggieBigJun 07, 2022Aspirant
hi sorry for not responding earlier.
let me provide more details
- I have a sky router and I use only AP mode for the orbi.
- The satellite is connected via back haul and I have no issue with internet and 5GHZ wifi connected deviced.
however 2.4 GHZ won't connect initially or if it does connect then it just drops connection after a few hours I have tried changing channel and the same issues persist.
Please note this is across several 2.4GHZ devices.
