BiggieBig
May 30, 2022Aspirant
Orbi rbk 353 2.4 GHZ connection issue
Hi, I’m using a sky router and have 2 Satellites. In a remote location all my 2.4 GHZ devices stop connecting. They work during initial setup and then they all lose connection. I’ve tried the ma...
- Jun 07, 2022
Hi,
Had the same issue, could solve it by changing these settings:
Advanced - Advanced settings - Wireless settings:
2.4GHz:
- Uncheck the 20/40 Mhz coexistance
- Preambule modus : Long
Also see this thread:
Good luck!
GroundGio
Jun 07, 2022Guide
Hi,
2.4GHz:
Good luck!
BiggieBig
Jun 10, 2022Aspirant
Wow thanks for this I tried this and it’s been stable for a Week.
Many thanks as I was almost in the process of looking for alternatives.
- FURRYe38Jun 10, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
