koentjuh195
Jun 19, 2022Follower
Orbi RBK 353 dropping wireless connection a few times a day.
Hi All, I have this issue for a while now, tried almost everything suggested in related posts but nothing works. Also I've read a lot of similar posts, but so far i can't find any issues exactly...
Jun 20, 2022Guru - Experienced User
What isp modem is it?
You put your have the orbi in AP mode. Meaning its not managing dhcp at all, the primary router is.
If you can connect to orbi AND the built in speedtest is working, I'd actually be looking at the ISP modem.
Have you tried putting the orbi in router mode and setting its IP address into the ISP modem's DMZ?
