akoMN
Feb 18, 2021Aspirant
Orbi RBK 750 Static Route to Modem UI, Starlink
I connected an RBK750 router to my Starlink dish directly, which means I replaced the Starlink router. The Starlink dish has an internal IP address 192.168.100.1 with statistical data that I want to...
Feb 18, 2021Guru - Experienced User
Ask your ISP if there modem/router is required for use wtih there hardware. Some ISP may require there HW to be used.
- akoMNFeb 18, 2021Aspirant
The ISP is Starlink and the modem is their dish. I already skipped the Starlink router and connected the RBK750 directly. Works all fine. I only want to have a static route from my network to the modem's statistic page.
I found out that it works when I use the to public IP address assigned by the ISP as Gateway IP address instead of the internal router address 10.0.0.1.On other routers, I would try 0.0.0.0 as the gateway, but the RBK750 refuses to use this address ("invalid gateway address").
akoMN wrote:
I found out that it works when I use the to public IP address assigned by the ISP as Gateway IP address instead of the internal router address 10.0.0.1.Unfortunately, it works only until a new public IP iss assigned by the ISP. So this is not a solution.
- MacrichFeb 20, 2021Tutor
I am also trying to hook up my Orbi to Starlink to access the stats on the app. Where do I find the public IP address assigned by Starlink to use as the Gateway IP address? Is it Basic/Internet/Internet IP address/Gateway IP Address ?
- FURRYe38Feb 18, 2021Guru - Experienced User
I'd ask the ISP what there IP address of the modem is. Most cable modems use 192.168.100.1 which passes thru most routers to connected PCs. Something to ask your ISP about.
- akoMNFeb 19, 2021Aspirant
FURRYe38 wrote:I'd ask the ISP what there IP address of the modem is. Most cable modems use 192.168.100.1 which passes thru most routers to connected PCs. Something to ask your ISP about.
The modem IP address is indeed 192.168.100.1, but it doesn't pass thru the RBK750 router. Still looking for a reliable solution to add a static route for this. Seems to be a lacking feature of an otherwise great product.
