akoMN
Feb 18, 2021Aspirant
Orbi RBK 750 Static Route to Modem UI, Starlink
I connected an RBK750 router to my Starlink dish directly, which means I replaced the Starlink router. The Starlink dish has an internal IP address 192.168.100.1 with statistical data that I want to...
Feb 18, 2021Guru - Experienced User
Ask your ISP if there modem/router is required for use wtih there hardware. Some ISP may require there HW to be used.
akoMN
The ISP is Starlink and the modem is their dish. I already skipped the Starlink router and connected the RBK750 directly. Works all fine. I only want to have a static route from my network to the modem's statistic page.
I found out that it works when I use the to public IP address assigned by the ISP as Gateway IP address instead of the internal router address 10.0.0.1.
On other routers, I would try 0.0.0.0 as the gateway, but the RBK750 refuses to use this address ("invalid gateway address").
