VPorbi
Apr 27, 2022Star
Orbi RBK 753 - one satellite not syncing - need help!
 Hello,    After working for almost a year, one of the satellite of my Orbi RBK 753 mesh is not working/syncing. It was solid magenta this morning and I have done the following:     1. Power reboot  2...
Apr 27, 2022Guru - Experienced User
have you tried hardwiring it into the router and syncing it that route?
VPorbi
Apr 27, 2022Star
No…can you describe the setup and process to do it? Thanks
- plemansApr 27, 2022Guru - Experienced User
Connect an ethernet wire from the router to the satellite.
then try to run the sync satellite process.
You can move the satellite to where the router is for ease/shorter wire
- VPorbiApr 27, 2022StarOk … just to confirm… connect the LAN port of Satellite to LAN port of Router and then press the sync buttons on each, right?
Tried it as described above…did not work…still flashing white…have done multiple factory resets, tried syncing through app on iPhone, pc and pressing sync button on satellite and router …nothing works…don’t know what else to do???
