Swedcouple
Oct 21, 2023Tutor
Orbi Rbk 753
I have several problems. The first is HOW and where can I connect to the routers webinterface? No one can explain this to me. Second, we had a device connected to our system, I paused this device in t...
michaelkenward
Oct 21, 2023Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Log in to the Orbi router web interface
Second, we had a device connected to our system, I paused this device in the app so the device had no connection to the internet.
What was that devuce?
Which app is this? Android or iOS?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
- SwedcoupleOct 21, 2023Tutor
I have checked all documentation i have. We have had this product now for over a year and still no one can help me login! The orbilogin DOES NOT WORK, i have put in admin and password, i have tried admin and my wifi password, nothing works. I have tried logging in via the IP direct adress, NOTHING WORKS!
This is a very expensive product and not a single person can explain how to login and perform the most basic tasks.
The device connected is an android phone. I am using the app on IOS.
- michaelkenwardOct 21, 2023Guru - Experienced User
That raises another question that I didn't add because it gets too long.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
This is a very expensive product and not a single person can explain how to login and perform the most basic tasks.Before anyone can begin to help, they need to know what is happening at your end. I'm afraid that "it does not work" offers no useful diagnostic detail.
What happens when you try to login? Any messages?
What is this "IP direct address"? Is that the LAN IP address 192.168.1.1?
