stuaid
Jan 11, 2023Tutor
ORBI RBK 762 2.4G signal not operating at maximum speed
Hi everyone, The 2.4G WiFi of my Orbi RBK762 system is operating at 286.8 Mbps. I have already turned off 20/40 MHz Coexistence and I have also tried other channels. Preamble Mode is set at Autom...
Jan 11, 2023Guru - Experienced User
Maybe a Web UI display code error here.
Log into the RBS web page and see what is displayed there?
Do you have any devices that can actually connect to the 2.4Gb radio to see what actual connection rate is seen?
What browser are you using?
CrimpOn
Thanks for providing the screen shot. It appears that this system is using only one 20MHz 2.4G channel. Can you check whether AX is enabled or disabled on 2.4G?
My RBR50 shows this:
