stuaid
Jan 11, 2023Tutor
ORBI RBK 762 2.4G signal not operating at maximum speed
Hi everyone, The 2.4G WiFi of my Orbi RBK762 system is operating at 286.8 Mbps. I have already turned off 20/40 MHz Coexistence and I have also tried other channels. Preamble Mode is set at Autom...
Jan 11, 2023Guru - Experienced User
Ok, that helps.
Please post the screen capture of the RBS web page now. Edit out the SSID name there before posting.
Is 40Mhz Co-existence only enabled Under Advanced Tab/Advanced Settings/Wireless Settings
stuaid
Jan 11, 2023Tutor
Not exactly sure which web page you are referring to. This is the one I see if I type in the satellite's ip address into my browser.
Coexistence is NOT enabled as I thought this could half the maximum speed?
- FURRYe38Jan 11, 2023Guru - Experienced User
Yes this is the page.
Thank you.
You might go head and open a support ticket on this. Seems to be either a UI Display issue or a FW issue.
Spec sheet shows 600Mbps support on 2.4Ghz. - FURRYe38Jan 17, 2023Guru - Experienced User
Any progress on this?
- ethanchuehJan 17, 2023AspirantDid this issue solved ? I have exact same problem with my RBK762, which 2.4GHz runs only 286mbps. Disable 20/40 co* already, no help.
- FURRYe38Jan 18, 2023Guru - Experienced User
What firmware is loaded on your system?
