wh1tby
Jul 19, 2021Aspirant
Orbi RBK 850 series setup issues
I am trying to install an RBK 853 (850 router with 2 satellites) with the latest firmware to replace an aging and now deprecated Apple Airport Extreme system (consists of an Airport Time Capsule as a...
Jul 19, 2021Guru - Experienced User
I would do the following, wire connect a PC or laptop and use a web browser, IE11, MS Edge, FireFox or Opera. Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Walk thru the setup wizard found at 192.168.1.1...You should be able to complete the wizard and get to the main home screen on the Basic Tab. I would not enable Armor. Go in and set up the router for your IP addressing needs here as well if you want to. Be sure to give and configure a new wifi SSID name. Can be most anything. Something fun and unique. :smileywink:
After it's setup save off a backup configuration to file for safe keeping. Saves time if a reset is needed.
See how the system works for this configuration. At a later point, if you want Armor and other features enabled, enable them and then save off another backup configuration to file for safe keeping. Then you'll have a couple of backups to use should something go wrong.
After the system is setup. The iphone and Orbi app should connect to it and work well. If it doesn't, try to remove the Orbi app then re-install it from the Apple store.
Be sure to visit the Orbi AX forum for your FW and HW help and supporting information as well:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
wh1tby
Thank you for taking the time to reply.
House size and ISP modem type were in my original posting. Satellite detection was not an issue and they wer all detected and configured correctly by either the iOS or browser set up process. One is 15' from the router and the other is around 35' to 45' away on the next floor. There never seemed to be a problem with finding and connecting to the satellites during the setup process. Backhaul signal strength was excellent for both satellites.
1. Browser access: I used Edge, Chrome, Firefox and Safari all with the same result (I do not use IE or Opera). Used either direct via ethernet port on the router or via wifi. Used either Apple MacOS systems or MS Surface Laptop 3 for connection. Did not make a difference.
2.I had already tried logging in using 192.168.1.1 (the default router IP address on the LAN) and using the orbilogin.com suggested in the instructions.
3. I tried using the iOS app and browser log in to configure the system from scratch. I could always configure and set up the system but could never log in again after that as per my original post. Setup would work fine from factory default or after a reset, but thereafter I could never login again either via the browser or iOS app.
4. Reset as per my original email was achieved by inserting a paper clip into the reset and holding for 30 to 40 seconds (instructions say until LED on the rear turns amber). The router always returned to default configuration for wifi access and configuration.
5. I deleted and reinstalled the iOS app 3 times, with no change in result. I could configure the system from reset or factory default but then could never get access again.
6. SSID and password were set to the old one used on previous system so I could allow all 42 internet devices to connect without having to reconnect each one to a new wifi network with a new SSID. I did try it with another random name (albeit without connecting any of my existing wifi connected devices), but I still had the same issue with login after configuration, and the internet connection and wifi would dissappear as per my original email.
7. I discovered your link to saving config files which helped a little but ulitmately made no difference to the fundamental issue.
8. Thanks for the link, and I tried a number of ideas that seemed to have no effect on the ultimate outcome.
Bottom line is that I can configure and set it up, but I can never access the router again and the internet connection and wifi would dissappear after 2 to 3 hours of operation.
Again I much appreciate the suggestions and attempt to help me with my dilemma.
