jk_89
Sep 27, 2021Aspirant
Orbi RBK 852 slow / won't finish loading / buffering
Hi all I purchased my Orbi RBK 852 in June (about four months ago) and had set it up successfully then. It came with the router and one satellite. I still use the modem provided by my ISP, which is...
- Sep 28, 2021
What mode is your modem working in? Router or modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Sep 28, 2021Guru - Experienced User
Couple of options,
- jk_89Sep 29, 2021Aspirant
Thanks FURRYe38 , I think I have successfully implemented solution 1 (configuring the modem to in bridged mode only). Am going to see how it goes over the next 24-48 hours before marking this as resolved. So far, it looks good, but not making any grand calls yet!
- FURRYe38Sep 29, 2021Guru - Experienced User
đ
I'm still having some issues, but specifically with remote login for my work when I work from home. I can connect and open my remote desktop, but performance quickly degrades. It is as though it is not fully loading things - when I swap applications on my remote desktop, it only loads the screen in pieces/chunks and stops eventually, becoming unresponsive. I can close and re-open but the issue creeps back in after 30 seconds or so.
I was reading a whirlpool thread about my specific modem, the TG-789, and I have the following questions:
- I use PPPoE and have input the details provided by my ISP on the "internet setup" page of the Orbi admin login. For connection mode, should I be selecting "always on" or one of the others?
- Under Advanced > Setup > LAN setup, should I be changing any details in there for IP address or "use router as DHCP server"? Someone posting on the whirlpool thread mentions the following: "I've also disabled DHCP on the 789 and changed its IP to 192.168.1.2 and set my DHCP to start from 192.168.1.3 on the router". Do I need to check these IP addresses on the modem/router?
- What other things should I change to improve performance for remote login? I changed the MTU size down to 1400 but this doesn't seem to have done anything.
Thanks again!
