jk_89
Sep 27, 2021Aspirant
Orbi RBK 852 slow / won't finish loading / buffering
Hi all I purchased my Orbi RBK 852 in June (about four months ago) and had set it up successfully then. It came with the router and one satellite. I still use the modem provided by my ISP, which is...
- Sep 28, 2021
What mode is your modem working in? Router or modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jk_89
Sep 29, 2021Aspirant
Thanks FURRYe38 , I think I have successfully implemented solution 1 (configuring the modem to in bridged mode only). Am going to see how it goes over the next 24-48 hours before marking this as resolved. So far, it looks good, but not making any grand calls yet!
Sep 29, 2021Guru - Experienced User
- jk_89Sep 29, 2021Aspirant
I'm still having some issues, but specifically with remote login for my work when I work from home. I can connect and open my remote desktop, but performance quickly degrades. It is as though it is not fully loading things - when I swap applications on my remote desktop, it only loads the screen in pieces/chunks and stops eventually, becoming unresponsive. I can close and re-open but the issue creeps back in after 30 seconds or so.
I was reading a whirlpool thread about my specific modem, the TG-789, and I have the following questions:
- I use PPPoE and have input the details provided by my ISP on the "internet setup" page of the Orbi admin login. For connection mode, should I be selecting "always on" or one of the others?
- Under Advanced > Setup > LAN setup, should I be changing any details in there for IP address or "use router as DHCP server"? Someone posting on the whirlpool thread mentions the following: "I've also disabled DHCP on the 789 and changed its IP to 192.168.1.2 and set my DHCP to start from 192.168.1.3 on the router". Do I need to check these IP addresses on the modem/router?
- What other things should I change to improve performance for remote login? I changed the MTU size down to 1400 but this doesn't seem to have done anything.
Thanks again!
- raven_auSep 29, 2021Virtuoso
jk_89 wrote:I'm still having some issues, but specifically with remote login for my work when I work from home. I can connect and open my remote desktop, but performance quickly degrades. It is as though it is not fully loading things - when I swap applications on my remote desktop, it only loads the screen in pieces/chunks and stops eventually, becoming unresponsive. I can close and re-open but the issue creeps back in after 30 seconds or so.
- What other things should I change to improve performance for remote login? I changed the MTU size down to 1400 but this doesn't seem to havThanks again!e done anything.
I have an old TG-789.
First question:
I don't use PPPoE but, yes I'm pretty sure that needs to be put in the Orbi internet config.
AFAICS there is no "always on" setting or anything else like it.
Second question:
I don't know but and I can't remember if I disabled the DHCP server on the 789 when I put it into bridge mode, that was a long time ago. I also disable the wireless on the 789 using the buttons on top as sometimes I want to check the connection so I connect to the wireless.
Diabling DHCP on the 789 should not need to be done regardless, it's on a different network to the Orbi.
I haven't needed to change anything on the 789 for it to work well.
raven_au wrote:I haven't needed to change anything on the 789 for it to work well.
Make sure you don't plug anything except the Orbi into the 789, I have observed problems in bridge mode when a second device was plaugged in to it to check settings and I rebooted the Orbi.
I have also found that if the internet connection fails to come up I need to unplug the ethernet cable from the 789 for 3 minutes or more before it will work again but that could be something to do with my ISP.
