Becksi
Dec 07, 2023Aspirant
Orbi RBK 853 - additional satellites
how can I add new satellites into an existing configuration, if the new satellites were used previously in another network. Although it’s the same type, the existing network doesn’t include them. When...
- Apr 05, 2024I have turned all the satellites off and then connect the new one first. Afterwards I turned on the other ones.
Dec 07, 2023Guru - Experienced User
FW the same version on the RBS and what's on the current RBR?
What firmware version is on the current running system?
What model are these RBS? 850 series?
Becksi
Yes, they have all the Same firmware: V7.2.6.21
It’s All the Same Series RBK 853.
