Becksi
Dec 07, 2023Aspirant
Orbi RBK 853 - additional satellites
how can I add new satellites into an existing configuration, if the new satellites were used previously in another network. Although it’s the same type, the existing network doesn’t include them. When...
- Apr 05, 2024I have turned all the satellites off and then connect the new one first. Afterwards I turned on the other ones.
Becksi
Yes, they have all the Same firmware: V7.2.6.21
It’s All the Same Series RBK 853.
Dec 07, 2023Guru - Experienced User
IF all is loaded with same version of FW, then using the RBRs web page to Add Satellite to the system should work. I recommend turning OFF all other currently connected RBS while you get the incoming RBS connected.
How many RBS are deployed?
