Gaspi
Dec 13, 2020Follower
Orbi RBK 853 - Router fron led alwasy withe
Hi All Since 2 days I have an Orbi RBK 853. I setup Router and Satelite and it works fine actually! One thing I can not understand ist the the Router RBK850 connected via Lan cable to the...
Dec 13, 2020Guru - Experienced User
Gaspi wrote:Hi All
One thing I can not understand ist the the Router RBK850 connected via Lan cable to the Internet Modem works perfectly but the front led is always wite, no blinking just wite.
Is this normal? should I do something else? Usually sould swiss off if everithning is fine isn't it?
Thanks for you adwise
Regards Gaspare
