MSS37448
Oct 26, 2020Aspirant
Orbi RBK 853 and Orbi Pro
Hi, I am based in the UK and live in a "large house", which suffers from poor WiFi and WiFi dead spots. I am considering investing in a WiFi 6 Network System, as there at least 30 devices on t...
Nov 03, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Sorry about that, it was malformed... :smileyembarrassed:
MSS37448
Nov 04, 2020Aspirant
Thank you FURRYe38
the new link works.
Have a nice day
- FURRYe38Nov 04, 2020Guru - Experienced User
Good Luck.
- MSS37448Nov 04, 2020Aspirant
Hi FURRYe38,
Would you know if I can use Orbi RBK 853 with my ISP Router, by just turning the WiFI Radio off [i.e. do not switch the ISP Router into Modem Mode}. Would this work and are there ny drawbacks with this approach?
Thank you for yiour help and patience.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
