gjohn
May 13, 2020Initiate
Orbi RBK 853 slow speed despite fast connection
I have just finished installing a brand new Orbi RBK 853 system in our home Router is connecte to the internet via hte network providers Router (set in bridge mode) with a 1000Mbps Download line - ...
- May 13, 2020
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
May 20, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
Wired speeds are being tested?
What app are you using to speedtest with? Orbi app, RBRs speed test or ooklas installable speed test app?
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Adnim
May 23, 2020Star
I installed the new AX6000 Orbi with 2 RBS850 satellites. I added 2 old satellites from previous generation hard wired back to the RBR 853 ROUTER. However I'm not seeing the older RBS50 satalites share the load. Most traffic is on the new wifi 6 hardware but the older satellites are doing nothing despite being hardwired to router.
Some smart things are not getting a good enough signal to work, like outside smart lights.
Any suggestions?
I have about 53 internet things on the network in a big house.
thanks
Adnim
- FURRYe38May 23, 2020Guru - Experienced User
Please start a new post thread regarding this. Your issue is not related to this thread and needs a new post.
Thank you.
Adnim wrote:I installed the new AX6000 Orbi with 2 RBS850 satellites. I added 2 old satellites from previous generation hard wired back to the RBR 853 ROUTER. However I'm not seeing the older RBS50 satalites share the load. Most traffic is on the new wifi 6 hardware but the older satellites are doing nothing despite being hardwired to router.
Any suggestions?I have about 53 internet things on the network in a big house.
thanksAdnim
