gjohn
May 13, 2020Initiate
Orbi RBK 853 slow speed even with fast connection
I have just finished installing a brand new Orbi RBK 853 system in our home Router is connecte to the internet via hte network providers Router (set in bridge mode) with a 1000Mbps Download line - ...
May 13, 2020Guru - Experienced User
What is this home network that the RBR is connected too?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
I would turn OFF the RBS and speed test a wired PC connected to the RBR first. Then wireless at the router.
- gjohnMay 14, 2020Initiate
Thanks for the swift input.
Things look better now
Completely reset and re-installed the network - The error might have been that the satelites did not sync properly by WLAN with the router prior to be connected to the cables. Speed is now better and consistent - Would you suggest to leave the CTS and RTS Values to 2346 - The automatic setup has set those to 64 - Would appreciate your advice on this FURRYe38
- FURRYe38May 14, 2020Guru - Experienced User
Great to hear. Thanks for letting us know. Seems that the wireless sync first then ethernet after still seems to be a good process.
Run it for a while, if you are not in a noise wifi area with lots of neighbors near by, you can raise the value back up. Or if you notice some of your devices don't connect well or at all. I saw with this NEST controllers so I raised mine up.
