gjohn
May 13, 2020Initiate
Orbi RBK 853 slow speed even with fast connection
I have just finished installing a brand new Orbi RBK 853 system in our home Router is connecte to the internet via hte network providers Router (set in bridge mode) with a 1000Mbps Download line - ...
gjohn
May 14, 2020Initiate
Thanks for the swift input.
Things look better now
Completely reset and re-installed the network - The error might have been that the satelites did not sync properly by WLAN with the router prior to be connected to the cables. Speed is now better and consistent - Would you suggest to leave the CTS and RTS Values to 2346 - The automatic setup has set those to 64 - Would appreciate your advice on this FURRYe38
May 14, 2020Guru - Experienced User
Great to hear. Thanks for letting us know. Seems that the wireless sync first then ethernet after still seems to be a good process.
Run it for a while, if you are not in a noise wifi area with lots of neighbors near by, you can raise the value back up. Or if you notice some of your devices don't connect well or at all. I saw with this NEST controllers so I raised mine up.
