Mytherin
Dec 01, 2021Tutor
Orbi RBK352: (DNS?) Issues after restart
A few days ago I got my Orbi RBK352. I have set it up in AP mode. The Orbi is directly connected using an ethernet cable to my primary modem/router. Everything works well and the internet/connectivit...
- Dec 01, 2021
What DNS is being used on the host router? ISP or custom?
Did you set up the RBR for a Dynamic or Static IP address for AP mode? Static IP address is recommended.
Dec 01, 2021Guru - Experienced User
Mytherin
Dec 02, 2021Tutor
I was using a dynamic IP address, switching to the static IP address seems to have solved the problem! Thanks.
> How often does the router restart? My router has gone six months without restarting. I have it on a small UPS to prevent 'power blips' from triggering a restart and only a 6 hour power outage was long enough to drain the UPS and force a restart.
In general very rarely, but I was doing some work that required me to turn off the electricity a number of times, hence my annoyance at the problem :)
- FURRYe38Dec 02, 2021Guru - Experienced User
Enjoy.
