JasperXIII
Aug 21, 2022Aspirant
Orbi RBK353 - Unstable internet & unstable connection to satellites
Hi all, This is my first post here. I recently bought a Orbi RBK353, but things haven't been going as planned... at all. I seem to have two issues, and I'm not sure whether they are linked. If n...
Aug 21, 2022Guru - Experienced User
I recommend you downgrad the RBR to same version as RBS, then upgrade the RBR FIRST. then upgrade the RBR lastly. RBS need to be udpated first alwasy before the RBR.
JasperXIII
Thanks for your reply. As mentioned in my initial post, I did do that after noticing it failed. A google search brought me to this community, where I read that. So I downgraded my RBR back to 4.4.0.10, then upgraded the RBSs to 4.4.1.29, then RBR to 4.4.1.29. Unfortunately, it didn't resolve the issue(s)
