Shovel-SR
Apr 16, 2023Aspirant
Orbi RBK353 (350 with 2 satellites) VPN Error on Android mobile
Hi all, I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (RBK350 router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service. The router F/w...
- Apr 16, 2023
Hi CrimpOn,
Thanks for the response. Your config is exactly the same as mine where it matters (obviously different server addresses etc - I use a NoIP DDNS pointing back to my router).
I have found a solution this afternoon though. Where the issue is, I still can't say especially as some users with OpenVPNConnect are fine, and others aren't.
The solution was to install another VPN client software, called "OpenVPN for Android" written by Arne Schwabe, and available on Google Play. While this is not my preferred option, as I would rather use the official app, it has solved the problem. It appears therefore that there is a bug in OpenVPN Connect. Odd, as other users are having no issues, and I didn't on my R6800. It only started once I had switched to the Orbi. I suspect that the "bug" is a mismatch between the Orbi server settings and OpenVPN Connect.
Interestingly, in order to eliminate a very similar issues on Windows, I had to add a line to the end of my config file:
Remote-cert-tls server
Whatever the issues are, the solution for Android is to install and use OpenVPN for Android, and not the official OpenVPN app.
Cheers
CrimpOn
Apr 16, 2023Guru - Experienced User
Bummer. This is using a config file produced by the new Orbi RBR350 router?
The Android configuration that I am using for an older Orbi RBR50 is this:
client
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973
resolv-retry infinite
nobind
persist-key
persist-tun
<ca>
-----BEGIN CERTIFICATE-----
OpenVPN Connect 3.3.1 , updated Feb 22, 2023 on Android 10.
The OpenVPN log file:
08:54:56.172 -- ----- OpenVPN Start -----
08:54:56.173 -- EVENT: CORE_THREAD_ACTIVE
08:54:56.175 -- OpenVPN core 3.git::d3f8b18b:Release android arm64 64-bit PT_PROXY
08:54:56.175 -- Frame=512/2048/512 mssfix-ctrl=1250
08:54:56.181 -- UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
13 [verb] [5]
08:54:56.181 -- EVENT: RESOLVE
08:54:56.392 -- Contacting 172.249.112.236:12973 via UDP
08:54:56.392 -- EVENT: WAIT
08:54:56.396 -- Connecting to [xxxxxxxxxx.mynetgear.com]:12973 (xxx.xxx.xxx.xxx) via UDPv4
08:54:56.585 -- EVENT: CONNECTING
08:54:56.588 -- Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
08:54:56.588 -- Creds: UsernameEmpty/PasswordEmpty
08:54:56.589 -- Peer Info:
IV_VER=3.git::d3f8b18b:Release
IV_PLAT=android
IV_NCP=2
IV_TCPNL=1
IV_PROTO=30
IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305:AES-128-CBC
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
IV_AUTO_SESS=1
IV_GUI_VER=net.openvpn.connect.android_3.3.1-9079
IV_SSO=webauth,openurl
08:54:56.685 -- VERIFY OK: depth=1, /C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear, signature: RSA-SHA256
08:54:56.686 -- VERIFY OK: depth=0, /C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=server/name=EasyRSA/emailAddress=mail@netgear, signature: RSA-SHA256
08:54:56.840 -- SSL Handshake: peer certificate: CN=server, 1024 bit RSA, cipher: ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
08:54:56.840 -- Session is ACTIVE
08:54:56.841 -- EVENT: GET_CONFIG
08:54:56.843 -- Sending PUSH_REQUEST to server...
08:54:56.997 -- OPTIONS:
0 [dhcp-option] [DNS] [192.168.1.1]
1 [route-gateway] [192.168.2.1]
2 [topology] [subnet]
3 [ping] [10]
4 [ping-restart] [120]
5 [redirect-gateway] [def1]
6 [ifconfig] [192.168.2.2] [255.255.255.0]
7 [peer-id] [0]
8 [cipher] [AES-256-GCM]
08:54:56.998 -- PROTOCOL OPTIONS:
cipher: AES-256-GCM
digest: NONE
key-derivation: OpenVPN PRF
compress: LZO_STUB
peer ID: 0
08:54:56.999 -- EVENT: ASSIGN_IP
08:54:57.021 -- Connected via tun
08:54:57.022 -- LZO-ASYM init swap=0 asym=1
08:54:57.022 -- Comp-stub init swap=0
08:54:57.023 -- EVENT: CONNECTED info='xxxxxxxx.mynetgear.com:12973 (xxx.xxx.xxx.xxx) via /UDPv4 on tun/192.168.2.2/ gw=[192.168.2.1/]'
- Shovel-SRApr 16, 2023Aspirant
Hi CrimpOn,
Cheers
- CrimpOnApr 16, 2023Guru - Experienced User
My DDNS is also through No-IP.com
Very puzzling. Where did my log file differ from yours?
- Shovel-SRApr 15, 2023Aspirant
Hi all,
I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service.
I had a VPN on my R6800 which worked for 5+ years without issues. Setting up the same service on my Orbi with new client configs for my windows and android devices has been less than inspiring, I have managed to get the Windows service working, but only after many hours of trying various web posted solutions. The one that worked for Widows was to add a line at the end of the config "Remote-cert-tls server".
However, adding that to the Android config fail achieves nothing. I get the exact same error and am now going round in circles. The full error message is:
Transport Error:OpenSSLCOntext::read_cleartext:BIO_read failed,cap=2576 status=-1:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
My config file is standard as produced by the router for Android - a smart_phone.ovpn which is a unified config with the certs and keys included.
I am using a DDNS (which is updated and working).
Anybody got any ideas?
Thanks
