Shovel-SR
Apr 16, 2023Aspirant
Orbi RBK353 (350 with 2 satellites) VPN Error on Android mobile
Hi all, I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (RBK350 router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service. The router F/w...
- Apr 16, 2023
Hi CrimpOn,
Thanks for the response. Your config is exactly the same as mine where it matters (obviously different server addresses etc - I use a NoIP DDNS pointing back to my router).
I have found a solution this afternoon though. Where the issue is, I still can't say especially as some users with OpenVPNConnect are fine, and others aren't.
The solution was to install another VPN client software, called "OpenVPN for Android" written by Arne Schwabe, and available on Google Play. While this is not my preferred option, as I would rather use the official app, it has solved the problem. It appears therefore that there is a bug in OpenVPN Connect. Odd, as other users are having no issues, and I didn't on my R6800. It only started once I had switched to the Orbi. I suspect that the "bug" is a mismatch between the Orbi server settings and OpenVPN Connect.
Interestingly, in order to eliminate a very similar issues on Windows, I had to add a line to the end of my config file:
Remote-cert-tls server
Whatever the issues are, the solution for Android is to install and use OpenVPN for Android, and not the official OpenVPN app.
Cheers
Shovel-SR
Hi CrimpOn,
Cheers
CrimpOn
Apr 16, 2023Guru - Experienced User
My DDNS is also through No-IP.com
Very puzzling. Where did my log file differ from yours?
- Shovel-SRApr 15, 2023Aspirant
Hi all,
I just switched from a nighthawk R6800 to an Orbi RBK353 mesh (router and 2 satellites). I am really pleased with the Orbi generally, except for the VPN service.
I had a VPN on my R6800 which worked for 5+ years without issues. Setting up the same service on my Orbi with new client configs for my windows and android devices has been less than inspiring, I have managed to get the Windows service working, but only after many hours of trying various web posted solutions. The one that worked for Widows was to add a line at the end of the config "Remote-cert-tls server".
However, adding that to the Android config fail achieves nothing. I get the exact same error and am now going round in circles. The full error message is:
Transport Error:OpenSSLCOntext::read_cleartext:BIO_read failed,cap=2576 status=-1:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
My config file is standard as produced by the router for Android - a smart_phone.ovpn which is a unified config with the certs and keys included.
I am using a DDNS (which is updated and working).
Anybody got any ideas?
Thanks
- Shovel-SRApr 17, 2023Aspirant
I dont know why, but any reply I put up here is disappearing. I have tried 4 times to respond with my log file but as soon as I hit post, the message flies off into the aether.
OK so that last one stayed up. It must be I'm doing something wrong with the log file. AS it is so small, I was pasting it inline directly to the post from a plain text file (so no markup). I can only assume the system has an issue with that for some reason.
I can't see how to upload the file, as the attachment box below won't accept anything other than PDF or images.
I have attached the log as a PDF
