Misquet
Sep 28, 2021Tutor
Orbi RBK353 AC Adapter
Hi, Looking for a while now for a third party alternative AC Adapter for Orbi RBK353. Any suggestions, as I am complete newbie? Bought a set without the ac adapters and waiting for it to arrive. ...
- Sep 28, 2021
All my orbi devices (SXK30, RBK43, RBK53) use the same 12v plug with a 5.5mm diameter and 10mm long plug.
I checked a couple of my other 12v devices from netgear and the couple I checked use the same 5.5 x 10mm size.
My netgear devices that run off 19v user a large plug diameter.
Sep 28, 2021Guru - Experienced User
