ABinaku
Dec 04, 2021Aspirant
Orbi rbk353 ax1800
I have the orbo rbk353 for about 2 weeks i kept it in router mode for about 1 week and then changed it to ap modus. The problem im facing is that the orbi router is giving out a solid purple light an...
Dec 06, 2021Guru - Experienced User
Be sure your using the Yellow WAN port to connect the RBR to the host router, even in AP mode...
Make sure cable between the host rouer and RBR is of good quality. CAT6 is recommended.
ABinaku wrote:
I have the orbo rbk353 for about 2 weeks i kept it in router mode for about 1 week and then changed it to ap modus. The problem im facing is that the orbi router is giving out a solid purple light and i don’t know why does somebody on this forum know the answer.
Modem/router: ZTE H369A
- ABinakuDec 06, 2021AspirantI gave my RBR connected from the wan port to the lan port on my modem/router and im also using the correct cable
