ABinaku
Dec 04, 2021Aspirant
Orbi rbk353 ax1800
I have the orbo rbk353 for about 2 weeks i kept it in router mode for about 1 week and then changed it to ap modus. The problem im facing is that the orbi router is giving out a solid purple light an...
ABinaku
Dec 06, 2021Aspirant
I was planning to try setting a static ip but i was wondering if it wasn’t bad have a static ip?
Dec 06, 2021Guru - Experienced User
Its not a bad thing. Helps to ensure the IP is set, the IP address doesn't change so you know where to access the RBRs web page at any time with out having to look at the host routers web page to find out what IP address was given to the RBR when using Dynamic IP mode.
