Hoots
Feb 03, 2023Aspirant
Orbi RBK353 connection to Dell Latitude E7440
I have recently added the Orbi RBK353 system and all good apart from one thing, I have an old Dell Latitude E7440 laptop which can't see the Wifi, I have read that if I turn off the AX then all would...
- Feb 03, 2023
Just select the "Accept Solution for the post that you mentioned that you got it working. 😉
Feb 03, 2023Guru - Experienced User
Instead of crippling your system, why not work at fixing the laptop?
What wireless chipset is in it and what driver is it running?
Some laptops you can upgrade the wireless card in them. That might be worth checking into.
Or buying a cheap usb wireless adapter to connect to it.
I'd go that route over decreasing the performance of your system.
- HootsFeb 03, 2023Aspirant
Hi, thanks for the response I have just uploaded updated software for the laptop wifi card and all is working ok now thanks.
- FURRYe38Feb 03, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- HootsFeb 03, 2023AspirantThanks for your advise how do you close the thread, new to this
