Hoots's avatar
Hoots
Orbi RBK353 connection to Dell Latitude E7440
I have recently added the Orbi RBK353 system and all good apart from one thing, I have an old Dell Latitude E7440 laptop which can't see the Wifi, I have read that if I turn off the AX then all would...
  • FURRYe38's avatar
    Just select the "Accept Solution for the post that you mentioned that you got it working. ğŸ˜‰
