Hoots
Feb 03, 2023Aspirant
Orbi RBK353 connection to Dell Latitude E7440
I have recently added the Orbi RBK353 system and all good apart from one thing, I have an old Dell Latitude E7440 laptop which can't see the Wifi, I have read that if I turn off the AX then all would...
- Feb 03, 2023
Just select the "Accept Solution for the post that you mentioned that you got it working. 😉
Hoots
Hi, thanks for the response I have just uploaded updated software for the laptop wifi card and all is working ok now thanks.
Feb 03, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
