Giobatta
Jan 31, 2023Aspirant
Orbi RBK353 Keeps Re-Synching
Two weeks ago I got an Orbi 353 to replace a mesh system provided by my ISP. The router and the two satellites run V4.4.1.29 software. The router and one of the satellites are installed downsta...
Giobatta
Thanks for the response.
The key issue is with the connection stability of one specific satellite. I fail to see how the ISP or the cable to the router could impact that.
What seems to be happening when this resyncing takes place is that the is that the upstairs satellite which is usually connected to the router over 2.4 GHz then tries to switch to 5 GHz and immediately falls back to 2.4.
The place is a medium size apartment so distances are fairly short. Also, the issue is never with the bandwidth I get - I am fine with that. It’s with the continuous re-synching
Jan 31, 2023Guru - Experienced User
Please give feedback to the questions presented. Please try the suggestions to see if anything changes the one RBS behavior.
The more information and feedback you give the best we can know what maybe happening and better help you out.
Thank you.
