Giobatta
Jan 30, 2023Aspirant
Orbi RBK353 Keeps Re-Synching
Two weeks ago I got an Orbi 353 to replace a mesh system provided by my ISP. The router and the two satellites run V4.4.1.29 software. The router and one of the satellites are installed downsta...
Jan 31, 2023Guru - Experienced User
Who is your ISP?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try swapping RBS with each other to see if the problem remains or follows the one RBS.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
If it continues, turn OFF the RBS, Then remove the disconnected RBS from the RBRs web page entry.
Bring the RBS to the same room as the RBR and resync the RBS wirelessly. Make sure the front LED turns blue then turns OFF. Might leave it here for a bit to check to see if it remains OFF.
Giobatta
Jan 31, 2023Aspirant
My ISP is Bezeq using a 600/60 GPON fiber connection and the RBK is connected via an Adtran SDX611 ONT using the cable that came with the RBK.
Apartment is 1300 SqFt, downstairs satellite is about 12 feet from the router and working fine. Upstairs satellite is about 30 feet from router with open staircase with concrete structure.
Tried swapping the satellites and the issue remains upstairs.
- FURRYe38Feb 01, 2023Guru - Experienced User
So 12 feet is TOO close between the one RBS and the RBR. 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Turn OFF this closer RBS and see if the other RBS at 30 feet will correct correctly. Maybe more it 5 feet closer to the RBR.
If you swapped RBS locations with each other and the problem didn't follow then there is a possible interference issue at this remote location.
For that size of home you only need the RBR and maybe 1 RBS. I'd even turn down the power on the RBR to 50% as well. Under Advanced Tab/Advanced Settings/Wireless Settings
- GiobattaFeb 02, 2023Aspirant
Thanks for the feedback 🙏
The downstairs satellite is there to provide wired ports for appliances that do not support Wi-Fi.
I now moved it to about 18 feet away from the router.
Is there a way to lower power in a specific satellite?
Your suggestion to reduce power in the RBR - would it not affect its capability to reach upstairs?
Also - I see that power can be managed separately for 2.4 and 5 GHz. Do you suggest I reduce it for both?
Again - many thanks for your support
- FURRYe38Feb 02, 2023Guru - Experienced User
Regardless if your using the closer RBS for just wired connections, there is wifi still being broadcast and having too much wifi over lap between the RBR and RBS and devices can cause problems.
I would first turn OFF the closer RBS to ensure that the other remote RBS is syncing fully and doesn't continue to re-sync and blink all the time.
You can only change the power on the RBR which will cause the RBS to change there power levels as well. Can only be done on the RBR.
Yes reduce both.
