mb2577
Nov 10, 2021Aspirant
Orbi RBK353 keeps rebooting
Hi. I insalled an Orbi RBK353 system at the end on May and after a couple of weeks it started to lose wi-fi with the LEDs going through the process of updating the configuration setting, accordin...
mb2577
Hi.
This is the link to the Orbi LED status light.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
The firmware of the router is v4.4.0.10_2.10.63 which is the latest version as of writing this. The modem I use is a Virgin Media Hub 4. This was installed on Monday 08/11/2021. Previously the modem was a Virgin Media Hub 3. But the satellites still keep playing up. Both modems are used in modem only mode.
The modem does have LAN ports but all my ethernet cables are plugged into the router including my mac. Only the Orbi router is connected to the modem. When the satellites drop out my mac is still connected to the internet so I'm assuming the modem is ok. The support pages suggest makeing sure the time zone is correctly set so that it only updates during the night, which it is.
Thanks.
michaelkenward
Nov 10, 2021Guru - Experienced User
Does this mean that you have been into the browser graphical user interface and configured it in "bridge mode"?
There is more to "bridging" a modem than plugging into the right LAN ports. (I assume that the Orbi is plugged into the Virgin hub.) You have to go in and tweak the settings.
I ask because of one recent conversation here where a user insisted that they were using a modem/router in modem mode, but after much toing and froing it turned out that they had got it wrong. That wasted a lot of time.
Fortunately, it looks like Virgin hubs can work in modem only mode, unlike the horrible BT Homehub.
As this is a new hub, did you reset the Orbi router when you swapped modems? This isn't a simple swap out process. You need the Orbi to forget any past association with the old hub.
- mb2577Nov 21, 2021Aspirant
Hi.
I don't know what 'bridge' mode is but the Virgin hub is definitely in modem mode. Just rebooting the router to see if it makes any difference. The only thing that I have ever changed on the router are the SSID, wi-fi and admin passwords.
Mick.
- michaelkenwardNov 21, 2021Guru - Experienced User
Bridge mode is another term for modem only mode. (Confusingly, there are also other "bridge modes".) Many manuals refer to it as bridge mode. That is also how to do a web search for modem only mode.
Unfortunately, there is a lot of confusion around these things. People sometimes turn off the wifi on a modem/router and think they are in modem only mode. Nope. They have just turned off the wifi.
Some ISPs – think the dreaded BT – also supply modem/routers that you just cannot put into modem only mode.
